1 - 2 of 2 Posts
Hello I have a issue with my truck that I have been trying to figure out for about a year now. I have a 1993 Chevrolet 2WD C2500 truck with a 4.3L TBI in it and a 4l60e (I think). I swapped to a 1994 7.4L tbi 4l80e 4WD. I drove this donor truck before I took everything out. So all I had to do was change the output shaft to work with 2wd and my drive shaft witch I did. I used the donor Engine,Wire harness, Transmission and PCM. Both these trucks have the 7060 PCM. I had a reluctor ring and VSS sensor added to the 4l80e for 2wd use. My issue is that I am getting is the PCM is not picking up the output shaft speed (VSS error). I tried 2 other sensors and I get the samething. BUT when I put the 4.3 tbi PCM in the transmission shifts perfectly just no OD and the engine runs like crap. Is there something I am missing? Is it having a issue because it was originally 2wd? With the 7.4 TBI ecm the engine runs amazing but goes into limp mode.
You probably know this, on the 2wd trucks the vss sensor is in the transmission tailpiece; on the 4wd trucks, it's in the transfer case, where it bolts to the transmission. Some trucks have 2 sensors, one for vss and one for abs.
If you have two sensors, could they be reversed?
1 - 2 of 2 Posts
