Discussion Starter #1 (Edited)
4L60 or 5 speed?
I have a 1992 Gmc Sonoma Gt with a 4L60 behind a 4.3 Vortec. I've heard a lot of bad things about the 4L60 and seem to be experiencing one now. 1-2 shift chirps them tires or scoots the hind end side ways depending on my current driving surface and throtle amount. What all do I need to change out the auto for a stick? I know I'll need a flywheel, clutch, pedal, hydo clutch cylinder. Will I need a new bell housing or crossmember? Which model trans would be best?
I would just have the 4l60 rebuilt. They have updated/heavy duty parts for them now and most of the problem area's with them have been improved on.
Discussion Starter #4
Thanks Silveradotrailblazer. That's what I'm thinking because I prefer an auto to a manuel. My hands are usually too busy doing something else in the truck to shift all the time. But I do want a slap shifter for those times I'm playin around. And 1991 Suburban, it was cool for the first 3 days but now it's starting to hurt. The non adjustable buckets don't help either.
NV3500 would be your best bet if you want to go 5 speed.
Otherwise, there is a ton of aftermarket for the 700R4 and the 4L60E. Mine is "mild" built IMO. I have BandM's 2400 Stall Converter, BandM's Shift Kit, "Beast" Sunshell, and 9 Pack Cluch Packs. Stock is 6. One of my next mod's is going to be the Corvette Servo also. If I end up building up a 383 stroker, I'll be looking at getting Yank's 2700 Stall Converter
