I purchased a 2007 gmc sierra nnbs from the auction and the transmission was missing.
I got my hands on a 4L65E "9LPD" . I was wondering what is needed to install with out any issues or any tips on what i may have to change.
mind you the 65e does not have the pnp plug on the side like the 60e.
any help is appreciated.
Thanks - Rick
06 to 09 use the 15 pin connector. Be sure the connector is correct. A couple different
The TAG ID 9LPD tag is for a 2009 GMC PICKUP C1500 4.8L 2WD 4L65E TRANSMISSION
You may have gotten lucky here. Confirm the converter bolts up to the flex plate before you attempt to install it.
Remember you will need the dipstick tube an converter bolts.
There is nothing at all that connects the transmission to a neutral safety switch, yes on trucks there is a PNP switch on the side with the manual shaft going through it, that switch only tells the pcm if it's in park or neutral (and turns the reverse lights on) you can remove anything on any factory equipped 4L60E/4L65E/4L70E that has anything to do with neutral safety, tie the wires together so it'll let the starter run. It's that simple. signal is coming from the stock pressure switch manifold inside the transmission. For park and neutral it reads 1st. There should be another wire to the pcm from the neutral safety switch on the shifter that signals the pcm that its in park or neutral.
Related Threads
GM Truck Club Forum
879.6K posts
98.7K members
Since 2000
A forum community dedicated to all General Motors truck owners and enthusiasts. Come join the discussion about performance, lift kits, wheels, tires, modifications, troubleshooting, maintenance, and more!
