1 - 6 of 6 Posts
I have a 2005 2500hd Sierra crew can 4x4 6.0 with a 4l80e that’s over heating and can’t figure out why. I’ve replaced the rad trans cooler cooler lines tranny temp sensor and the torque converter. Tranny shifts great just over heats flushed three times three different filters nothing on the magnet. Just even went after the cooling part of the motor new water pump tstat heater core flush and still the tranny is over heating. Any ideas
Howdy and welcome, Dub.
You might not have an actual overheating problem. If you can get an aftermarket gauge and check it against the dash gauge? Maybe even just a laser thermometer and check the oil line leaving the case? That would be the one that connects to the top of the radiator cooler.
My Allison gets an aneurism once in a while and will throw a temperature code when it’s ice cold.
That’s an even better thought.
  • Like
Reactions: thegawd
2001 Suburban 5.3L, 298k miles
Is your torque converter locking up? Slippage creates a lot of heat.
Man lately there are so many important questions asked and then absolutely no response from the people who asked the questions.
1 - 6 of 6 Posts
