1 - 4 of 4 Posts
My 04 sub which is 2 whl and is 3/4 ton has a 4L80E tranny and I am wondering if I can turn the converter on and off. The reason is that in my old sub which was a 96 2 whl 3/4 ton with a 5.7 and the same tranny, I could come off of the converter by a slight touch of the brake pedal. This was so cool when towing or going up a hill on overdrive. I have tried the same trick with the 04 but to no avail. The only thing I can do is depress the throttle down about 1 inch or so to get down a gear then let the throttle up a little.
Muffinman..
I have 2000 1500 with 5.3L and same transmission. Do you have the Tow/Haul switch on shift lever? If so, engage the tow/haul mode as it changes the shift pattern of the tranny and does it quite well.
If you don't have towl/haul, use 3rd gear only.
1 - 4 of 4 Posts
