I have a 1987 Suburban 3/4 ton that starts okay when its cold, but yesterday after I an a short errand in cold weather, I get back in the truck and it wont even crank or click. I fooled around for 15-20 minutes checking fuses, then turned the wheel straight thinking maybe it was something in the ignition column wiring, and whammy, it cranks right up. Then, I drive it the 3 minutes back home, park it, and try to start it again. And Its dead again.
I havent been out today to try it, but I wouldnt be surprised if it cranks.
The battery is strong, and the lights dim when I turn the key (which apparently shows the current hitting the solenoid).
After doing a little research, Things seem to point to a few things:
1. Starter Relay is acting up (at times??)
2. Old wiring not giving starter enough juice to kick in (at times??)
3. Hot-sticky starter that will have to rebuilt/replaced.
4. Funky short in wiring in ignition wiring harness
Any thoughts??
Any thoughts??
