1 - 2 of 2 Posts
I'm going to be starting a trans swap soon and I am looking for parts and prices. I'm in Albany, I need the transmission, Pedal assembly, And what ever else I'm not thinking of. please let me now price and location, Thanks. 92 1500 2wd 4.3. wanting automatic.
Sounds like you want to go from a stick to an auto trans? If so you need to find out what ECM/PCM you have. The 700R4 (4L60) isn't controlled by the ECM, the 4L60E is by a PCM. If you run with a 700R4 you'll need to add the TV cable and brackets to connect to your throttle body and a cable from your ECM to the trans for TCC (Torque Converter Clutch). If you are able to go with the electronically shifted trans, you'll need the cables that go from the PCM to the trans.
1 - 2 of 2 Posts
