I have a 92 k1500 silverado and im thinking about doing a ccm 2"-3" leveling lift kit and running 33x10.50x15 BFG all-terrains. do I need extended shock brackets? any suggestions or pointers to make this job easier?
Welcome to the club. If you go off-road or drive on bumpy dirt roads I would get Rancho's new shocks for leveled trucks.
u dont need to buy a kit just jack up the torsion bars they will give u 2-3 inches in front
If you do this, you will have to get the front tires re-aligned, because when you jack the front end up, you change all the angles affecting the tire, because its aligned to be perfectly straight at the height the factory set it at. When you jack the torsion bars, it'll cause excessive wear on the outside of the tire, and I'm not exaggerating when I say excessive.
