Hello, new to the forum. I have a lot of Fluid leaking from the front differential right where the 4x4 drive shaft goes into the diff. Is it just a seal that needs to be replaced or something else? If just a seal anyone have a part number? Thanks!
Your pinion seal is bad, you can get the part from auto parts stores. Replacing a pinion seal is not a big deal.Hello, new to the forum. I have a lot of Fluid leaking from the front differential right where the 4x4 drive shaft goes into the diff. Is it just a seal that needs to be replaced or something else? If just a seal anyone have a part number? Thanks!
