95 GMC K1500 Hazard Light Issue
72 Views 1 Reply 2 Participants Last post by  RayVoy
Hi. I've looked at several forums and haven't really seen my specific issue. My turn indicators work fine. If I push down on the hazard light switch on the steering column, nothing happens. If I have a trailer hooked up, and the switch is depressed, nothing happens, until I use a turn indicator. When I use a turn indicator, the truck shows it correctly, but all of the trailer lights flash as if the hazard button is depressed. If I pop the switch up, the trailer lights don't work at all.
Not really sure where to start.
  • Like
Reactions: 1
1 - 2 of 2 Posts
Ok, let's chase one fault (I suspect you only have one problem; but let's not complicate it).
You say, without the trailer connected, the turn signals work; but the 4 way hazards do not.
I would try to solve that problem first.
The signals and the hazards both work off the multi-function switch in the steering column.
I would remove the switch and inspect and test each of the positions.
1 - 2 of 2 Posts
