1 - 2 of 2 Posts
Hello everybody I have a 1995K 3500 I bought it in November of last year some wires for the four-wheel-drive front actuator melted on the exhaust and laid on the transmission without knowing I had the transmission rebuilt three times rebuilt the bottom of the motor put everything back together if you’re very light on the gas the truck drives fine shifts first second and third overdrive you step on the gas like a normal person would drive in a lock out and second gear
Discussion Starter · #2 ·
When the guy with the transmission rebuilt at the last time he left the actuator unplugged in the truck seem to drive and shift perfect the motor started knocking so I put a new crank bearings etc. in the bottom and put the motor back in and then it started acting up again as far as the shifting prior to the motor work we replaced the drac sensor as well
1 - 2 of 2 Posts
