Howdy:yes: ... Well sir ... when I have the ac on and turn on the fan the air will come through the vents next to the windshield, but not the vents that blow air on me.:surprised: Any idea what the problem could be?:neutral:
He's referring to the set of knobs that control the vent location, temperature, and fan speed. You pull the dash panel off to remove them.Do you know where this switch is located? Is it easy to remove and replace?
The S10 trucks use vacuum motors to switch the mode doors. If the doors are not operating, there could be a vacuum leak.
