New member here.... name is Mike... i just recently blew the rear end in my truck...
code in the glove box says GU6- which is a 3.42 ratio,
but the tag on my transfer case says 272 ratio... had the transfer case replaced about 6 years ago, have used 4 wheel in all modes without any problems since then... my question is why is the rear a 342 and the transfer case a 272?? and is this ok... ham is shattered, spider gears fell out when i opened it up, pinion also has chips along with planetary (sp?)
Thanks in advance..
Thanks in advance..
