Okay, so I just swapped out the transmission on my 97 2500. I wasnt able to drive the truck before I bought it because of the bad tranny, but it other wise seemed in good shape. Well I swapped out the transmission, and the 4x4 doesn't work, front driveshaft spins but the axle doesn't, so I replaced the front actuator. 4x4 still doesn't work, Also when I have the lever in 2x4 the heater motor will blow and run, but as soon as I drop it into 4x4 the heater quits. Could it be a grounding issue or what do y'all think? Thanks in advance.
