Mine was acting the same way. I finally decided to just let some pressure out at the shraeder valve on the inlet side of the pump and refill it. Not much came out, so I fired up the truck, got the ac up to operating temps (where it was blowing luke-warm at best) and started filling with a new canister of R134. It took the whole can and half of another one to get it back to the correct pressure. I'm guessing I had a bubble or wasn't reading it right or some such. All I know is that it works again, blowing cold front and rear, even at 110 degrees ambient air temp.
Not sayin' what I did was right or safe...I really don't know. I do know I took my time, started with a new guage and took the steps on the can step by step AFTER I got the engine to op temp and the ac blowing as cold as it would get. Then my pressures read much lower than they did before and it took the recharge and works.
