hey guys...!! I just replaced the 5.7 l in my 97 suburban.. well.. not as easy as I had thought.. a lot of tapes came off.. during the engine replacement, and I'm ready to put this thing together.. my question 1.;firing sequence of the 5.7 l vortec. numbers on the distributor is marked.. but just wanted to be sure of the ENGINE SIDE OF THE sprk plug cables.. driver side, and the passanger side....?? .. QUESTION 2.; distributor ROD placement.. ; what is the right way to have the timing of the rod.. what do I have to do to have right timing .... I know it's a electronic distributor, but I don't think I could just stick it in and expect it to have proper timing...QUESTION 3..;I did take out the torque converter with the engine, and did not fill it with tranny oil in it when I was putting it in.. what would be the right steps to take to get it right from here..???:neutral:. your help will be appreciated.. thanks.. jc..:neutral:
