When the running lights are on, the front passenger side turn signal will not work. And the light for that turn signal stays on inside the instrument panel. The bulbs are fine because they work while nighttime running lights are off. Very confused. Can not be the flasher or fuses since they work fine as long as the night time running lights are off. Any ideas?
You asked, in a PM, for more info.
The dirty ground is on the passenger front fender.
Check the light assembly for a ground wire (black) clean where it bolts to the sheetmetal.
Check the fender for a ground strap, it may be copper. If there is no ground strap, the metal grounds through the screws that mount the fender.
Discussion Starter #5
166679
You mean this ground just dangling like a nuts sack? Hahahhaha. Thanks again man.
