I have a 98 suburban and the passenger side window does not work at all. I replaced the window motor and the front driver and passenger side window/door lock switches. I have inspected all of the wires inside the door all the way back to where it passes through the grommet into the interior. I removed the glove box and inspected the wires as far up as i could see from there. I could not find any damaged wires here.
Also the drivers side rear window works off of the master switch at the drivers seat but not the switch on the rear drivers side door. I have not replaced any parts here or removed the door panel yet.
Does anyone have any suggestions?
The wire harness in the door has a connector where it meets the main harness inside the vehicle. Tomorrow I plan un unplugging the harness here and checking all the wires in the door harness for continuity.
Anyone have similar issues?
