1 - 3 of 3 Posts
My 99 Silverado sometimes will not start. Let me explain. The other day the battery was dead. Replaced the 5 year old battery it started right up. Drove it a day, parked it and the following day when I tried to start it, nothing. All lights were on, no dimming, no click no starter engagement. I moved the keyed form start to off several times and bang, it started right up.
Any ideas?
the starter could be bad. since no click in crank mode then the ignition switch or starter relay need be checked. move the shifter to park/neutral .
other items like the cables at the starter remove and clean and also at around the battery including the grounds. loose starter bolts also.
· Super Moderator
1 - 3 of 3 Posts
