F/S – 1999 Chevy Suburban 2500 Series ¾ Ton H.D. Big Block 454 * 86,000 Miles *
Up for sale is my mint condition 99 Chevy Suburban 2500 series HD SUV. I bought this SUV last year to pull my travel trailer with and it did a great job. I performed alot of upgrades and maintenance on this vehicle when I first purchased it thinking I would have it for a long long time. Fast foward to this year and my wife decides she wants a 5th wheel Trailer instead of our current bumper pull trailer. So now I have to buy a pick up truck and sell the Suburban.
Details:
99 Chevy Suburban 2500 3/4 Ton H.D. All black - secret service look alike
454ci Vortec Big Block Motor
4L80E H.D. 4 speed overdrive transmission
14 Bolt Corp Full Floating Locking Rear (G80 RPO CODE)
4.10 Gear Ratio (GT5 RPO CODE)
H.D. 1 Ton front torsion bar suspension (F60 RPO Code)
H.D. Tow Package
Auxillary transmission cooler
Auxillary Oil Cooler
Dual Batteries with 200 amp system isolator installed.
Auto Trac 4wd system
Recent Performance Upgrades:
K & N Cold air intake induction kit
Custom tuned P.C.M. by Jesse Bubb @ www.wait4meperformance.com (Stock PCM included in sale)
Flowmaster dual inlet / dual outlet muffler with custom dual pipes & chrome tips
Exterior:
16 x 8 American Eagle Alloy wheels
LT 245/75/16 Load "E" tires - less than 5,000 miles
CIPA Extendable power tow mirrors
All new front head lamp , parking light and turn signal assemblies. New bulbs in all
Front mounted draw tite 2inch hitch reciever
Rear mounted reciever hitch 2inch, 7 & 6 pin power connections
Full length running boards
Roof cargo carrying racks
Interior:
"9" passenger seating arrangement
AM/FM/CD/Tape Player
Pwr Steering, windows, mirrors, locks, cruise.
Pwr Brakes (H.D. 3/4 Ton Hydra Boost brake system)
Front & rear air conditioning
3rd row seating
Rear cargo area floor protector
Recent Maint performed (Within the last 5000 miles):
New lower intake manifold gasket
New water pump
Coolant system flushed
New fuel pressure regualtor
Full tune up (Plugs, wires, Dist cap & rotor)
** All of the above services were performed by the GM Dealer **
4 new Bilstein shocks
2 new u-joints & nickle plated pinion yoke (GM T.S.B.Article fix)
Rear Brake shoes and new wheel cylinders and hardware
Oil changed using MOBIL 1 Synthetic
Transfer case was just serviced usint GM Auto Trak II Fluid
Transmission fluid and filter were just changed
Rear Differential fluid was just changed
As you can see I did nto spare any expense on this truck, I planned on having it for a long long time. With only 86,000 miles on this truck the Big Block motor has probably not even reached 50% of its life yet. It really kills me to sell this truck after what I have put into it but as I said we need a pick up to pull a 5th wheel camper.
If you cant notice it in the pictures this truck is just about perfect, the paint is shiny with virtuially no scratches dings or dents. The interior is in great shape with no rips, tears or worn spots. Everything works as it should work with no hidden suprises. I have been over this truck with a fine tooth comb and it is about as perfect as you can get.
This is a special truck for a special person, if you need to haul 5 or 6 people and tow a boat or trailer this vehicle is for you. You can even pull the 3rd row seat out and fit a sheet of plywood in with the doors closed. You will not find a nicer Suburban out there in a 99.
I am going to cut right to the chase here, I need to move this Suburban before I can buy a new truck so my loss is your gain. I paid $11,000 dollars for this truck last year & 5,000 miles ago. I put over $3500.00 into it getting it near perfect as far as maintenance and upgrades are concerned. I just want my $11,000 back, as I said my loss is your gain. The first $11,000 cash gets the truck.
You can see pictures of the truck here: http://mysite.verizon.net/cenley/Suburban/
Note* The custom center console I built that houses a full Windows XP Computer & a 7 inch touchscreen LCD are not included in this sale and will be removed prior to purchase unless you are interested in the setup then we could talk about it. Just a FYI - The system is called a carputer, I use it for GPS navigation, I can play all my MP3's on it as well as any DVD movies or video clips. It provides wireless internet access while on the road as well. It also iterfaces with the back up camera so I can see behind me when hitching up a trailer or driving. The system is fully removeable as I built it in it's own case/console that fits on the floor and it can just be lifted out. The touch screen monitor is mounted to the cup holder that I purchased from ebay so I have the stock cup holder to be reinstalled when the system is removed.
Thanks for your time, you can email me at [email protected] with any questions or if you would like to arrange a showing of the vehicle. This truck is located in Souther NJ
http://mysite.verizon.net/cenley/Suburban/images/100_2210 (Small).JPG
http://mysite.verizon.net/cenley/Suburban/images/100_2212 (Small).JPG
http://mysite.verizon.net/cenley/Suburban/images/100_2220 (Small).JPG
http://mysite.verizon.net/cenley/Suburban/images/100_2223 (Small).JPG
Details:
H.D. Tow Package
Exterior:
Interior:
3rd row seating
New water pump
