1 - 20 of 26 Posts
Wondering is there is a test procedure to determine why the A/C clutch will not engage.
2002 Silverado 3500 LT
Symptoms: No cold air, A/C light on dash will light, fan door appears to work from dash to foot to mix to defrost positions.
Known: Freon charge is good, fuses (inside drivers compartment and under hood) verified good. Swapped out relay with another with no effect.
Thanks for any help on this!
Have you jumped the low pressure switch???
Discussion Starter #3
I haven't done that yet. If I do and the clutch still does not engage, what would be the next step? Trying to gather as much information as possible before I have to start then stop.
Thanks!
Sorry also jump the high pressure switch.. IF the still doesnt engage it then you need to run power directly to the AC compressor and see if the compressor engages then. If the Compressor doesnt engage with direct power from the battery then the Compressor is shot.
Discussion Starter #5
Thanks!
A couple of questions, the low pressure connection is on left side of the accumulator correct? Where is the high pressure switch? Would you suggest jumping both of these at the same time? A paper clip would probably do the trick I would think.
Also, how should I connect power to the compressor? There is a plug on the front/top of the compressor, I would assume this is where I would provide the 12V.
Pull the plug and connect 12v + to where and negative to where? I can pull the power from the front left battery.
Thanks again for your help!
Yes the low pressure switch is on the side of the accumulator, the High pressure switch loos very similar to the low switch and is on the lines somewhere i cannot recall at this exact moment. And yes you can jump them both at the same time though i would do them individually so you know which switch is shot.. if not both of them. And yes the plug on the compressor, and power from the battery with the motor running (you most likely already knew that i actually messed this up a while back when i got in a hurry)
Discussion Starter #7
If I understand correctly, I will connect one side of the battery (positive) to one side of the compressor and the other side (negative) to the other?
Yep.. just take a look at the harness plug (since there should be 2 wires) and remeber that the black wire is ground.. And the color wire will be your positive.
As stated, make sure the pressure switch on the accumulator is good.
Those switches are cheap (was for my truck, $5.00 I think).
Take a wire and run from the + terminal on the batter, and stick the other end into the power harness on the compressor. This should engage the compressor and the clutch.
Something you can do before jumping these guys, just to do an easy test first of all.
Is get some guages and check the pressure.
Since the A/C is not coming on, you should see pressure in the lines.
Even pressure on both High and Low sides, maybe about 50 - 100 PSI
This will confirm that you do have a sealed system and there is freeon in the line.
Simple and easy check.
Discussion Starter #10
The pressures have been checked and verified that they are where they should be.
I will assume that the jumper wires from the battery are going to go to the compressor itself, not the plug that is disconnected from the compressor correct?
Correct...
Right power has to go to the compressor.
The plug/boot that plugs into the compressor is what supplies the power to the compressor when the switch on the Accumulator tells it too, based on pressure in the system.
Hi all
So My AC system is not working and when the car is running the clutch on the compressor is not engaging. Just to be sure I am understanding correctly If I disconnect the low pressure switch and run a wire or paper clip to bridge the connector. If my clutch is not running because of low pressure or a bad switch then this would tell me if the clutch engages.
My next move would be to check the pressure and if good it is a bad switch and if it is low I need a boost.
I know some trucks have a combine Low pressure and high pressure switch it is not clear to me how to tell if that is in fact the case.
thanks
So how is it you know the charge is good if the compressor does not run?
you have to measure the pressure in the system with a gauge low side and high side should be equal and I have read somewhere between 50-100 Psi ( I have seen a large range of numbers.
T-bone, that will only tell you that there is refrigerant in the system but not how much.
Yes, but it will tell you that there is something in the system....so you can conclude that there is not a leak or a big one at least.
Now once the compressor is turned on, and running.....then you can see what the pressure rises/falls too.....and go from there.
1 - 20 of 26 Posts
