As I mentioned in my introduction, I have a 1988 Chevy 1 ton, it has Stahl service body on it. I am the second registered owner. It as originally titled to the Arizona Department of Natural Resources. More about that later.
I bought the truck in 2012. After doing a few things to it, it has always run very well. It only had 75K on in when I bought it. While driving a couple of weeks ago, I noticed a ping, or light tappet noise or something, I'm not sure. ,I added some Marvel Mystery Oil. My dad swore by that stuff. It didn't help. Then a few days ago while driving, it sort-a stumbled, but came right out of it. Then I noticed my volt meter was pegged to the max. This can't be good. Looking things over I found some burnt and crispy wires near the starter and exhaust manifold. One of the wires lead from the positive battery post to a junction block on the firewall. Another wire went from the starter solenoid to the ignition switch. The third was the wire going to the knock sensor. I replaced all the bad wiring, the knock sensor, and changed the oil. I don't know if the pinging (if it is pinging) and the burnt wires are connected in any way. All wiring is good now, and the volt meter is back to normal, but the truck has a slight hesitation and stumble when accelerating from a stop. It is a very slight hesitation, but it's there. Also, it doesn't seem to start as quick as it use too. It takes just a bit more cranking it seems, Back in the old days I would have replaced the points, set the dwell, and checked timing, I did order me a timing light, so I can at least check that. My question is, could the shorting of the wires damaged my ignition control module (ICM) in the distributor, or if it had been damaged, would the truck run at all? Is there something else I should be looking at?
Thanks for any help. Greg
