hi, I own a '95 suburban 4 x 4 with a 5.7 L. At intial start-up, the dash lights come on and go off as usual inc. the abs light. But as soon as the truck gets rolling the abs light stays on. Faulty module or what?
Highmileage this is from a later post that you may have already seen:Highmileage said:hi, I own a '95 suburban 4 x 4 with a 5.7 L. At intial start-up, the dash lights come on and go off as usual inc. the abs light. But as soon as the truck gets rolling the abs light stays on. Faulty module or what?
!!WARNING!! Disconnecting the bulb is a very bad idea! If the light comes on and stays on, it's because the system has detected a problem. If you don't feel confident in diagnosing the problem yourself, you should have it checked by a qualified technician. Ignoring the light doesn't help either.a lot of people disconect the bulb.
