1 - 4 of 4 Posts
Argh! Another bugg.. My ABS was dissabled on the truck and I thought it was fubared.. Today when giving it a tune-up I notice the harness was unplugged.
Plugged it back in and got ABS! Too much ABS! Now when I'm nearing full stop the ABS engages no matter what surface I am on.
Obviously why the dealer had it disconnected... What could be causing this? Wheel speed sensor? (Please tell me they are not built into the hubs...)
Bad abs module?
Is there a sensor on the brake pedle?
Thanks!
Eric
Bad abs module?
Thanks!
Eric
Abs Module
The dealer is not supposed to disconect that, if you have a safety inspection you will not pass.
I think that model year was rear abs only(I can't remember, yours) but I have heard mechanics doing this but not a dealership. Some people did not like the way back brakes acted. Have you checked that rear wheel cylinders are not leaking and axl seals?
Discussion Starter · #4 ·
It's front and rear abs on my truck. no leaks anywhere. had brake fluid replaced.
If I need to change the module, I'm in for it... The lines going in the module are sure to be seized. That means all new brake lines. ARGH!
I had a similar problem with my s10 Jimmy, with taht truck it was a bad wheel speed sensor.
Cheers!
Eric
1 - 4 of 4 Posts
