I have an issue that I am trying to resolve.
I have a 92 K2500 4wd 8600 GVW burb. I replaced both front rotors/calipers/pads the rears are adjusted properly. My abs light will intermittently come on then go off while driving. In the past couple of days also the red brake light will sometimes come on with the abs light ...ODDLY when you step on the brake BOTH lights will go off until you start rolling again then either just the abs light or both will come back on again. I have a good pedal and no issues with stopping the brake fluid is full and does not appear to be leaking the parking brake is not applied. Last ODD thing is my hazard lamps do not work correctly.
I have tried replacing the flashers no change.Last my brake lamps will stay on after releasing the brak unless i pull up on the brake pedal with my toe after taking off. Here are my questions. #1 I am leaning toward a failed brake lamp switch as the cause of the brake lights continuing to stay on and possibly might be the cause of the hazards not working --wondering your thoughts?
Could this also be related to the RED brake lamp coming on and off? I have tried retrieving the codes for the abs but I cannot seem to get them through jumping the aldl connector. I believe my hydrobooster might be failing as well but I do not think that would cause any abs or brake lamp codes as there are no electrical connectors attached to it. Any ideas on where to start first ?
