New to the group so if this is posted somewhere else please point me to it
I have a 98 gmc serra c1500. The blower was making an awful sound and a bit later the blower would only run on high. Fast forward a few years of not having ac or heat.
Decided to fix it...finally. so replaced the blower motor and resistor. Great. Now all the speeds work and the blower is blowing. But nothing is really coming through the vents.
Take the blower back out and clean the coil (realize now I should have done this when replacing the blower but live and learn). Check (best I can without moving the dash) the actuators and the fin move but it seemed one fell. Took that out and now the air blows better but not cold.
Check the compressor and it is not engaging. Great (sarcastically). But checked to see if it really was not working so I checked the compression switch, looked ok but unplugged the wire, used a paperclip to short it and the compressor engaged! Yea, means a bag compression switch. Easy.
Today, new compression switch and....nothing. no change. I don't know what to do next. I don't know gauges, and pressures, how to find leaks etc.
Any help would be amazing!
