1 - 3 of 3 Posts
Hi
would like to know how to adjust the door on a suburban 1990 Aust As my sister door has drop about 1/4in
And will not shut
Thank you for your time
All the best
Ben
You will need to loosen the door hinges and re-align. Make sure you have a few people to help. But, with that said, why is the door that low? Was it loosened or taken off recently? if not, then the first thing to do would be to install new door hinge pins and bushings. Common for them to go bad over the years, what with the weight of the door and opening and closing it a million times.
1 - 3 of 3 Posts
