Thanks very much. And thanks for the quick response. Great siteLook Ralph, here are the facts.
You can buy a device that will disable the AFM program in the ECM.
However, all of the AFM hardware is still there; and,
You still must use GM Dexos oil (read high quality synthetic) and a very good filter.
And change the oil at an appropriate interval.
There is a filter in the lifter oil passages that must also be changed.
So, in my opinion, if you do all of the above you are ensuring that the AFM components will live long lives and disabling is no longer a factor.
And.......Welcome to the site!
Thanks Kenny. Great response timesX2 on what Ray said. And welcome to the forum.
kill the AFM ...many have liked this widget because better shifting and they got slightly higher MPG.Thanks for letting me join. I purchase 2015 Silverado with 22,000 miles. Should I kill the AFM now before it does damage? It's driving me bonkers. Thanks Ralph S
No comparison, those engines disabled the values at the rocker arm (actually a better idea than collapsing a lifter in my opinion), they used very small and slow engine computers (it was the early '80s) and the computer relied on engine vacuum to tell it when to active and deactivated.I remember those Cadillacs from back in the day.
spend 200 bucks and no problems ..plug and play simple .Yeah I wouldn't pay 5 to $7,000 to get it repaired might as well drop in another engine. I remember those Cadillacs from back in the day.
read this post ..https://www.gmtruckclub.com/forum/threads/range-afm-disabler.1237809/Thanks for letting me join. I purchase 2015 Silverado with 22,000 miles. Should I kill the AFM now before it does damage? It's driving me bonkers. Thanks Ralph S
ok thanks for the info, I didnt know the official term, now I have some more knowledge!!It stands for Active Fuel Management.
The engines have a package of mechanical and computer parts and programs that de-activates some of the cylinders under light load conditions. The 10 year old (and a bit newer) trucks could turn off half of the cylinders (turning a V8 into a V4); the very new trucks can turn off up to 7 of 8 cylinders.
That's a nutshell overview, there is a lot more on the net.
You mentioned the filter in the lifter oil passage passages. I have a 2015 Yukon SLT. Where is it located? Never heard of it.Look Ralph, here are the facts.
