Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,500-6,800
Intake Duration at 050 inch Lift:226
Exhaust Duration at 050 inch Lift:226
Duration at 050 inch Lift:226 int./226 exh.
Advertised Intake Duration:275
Advertised Exhaust Duration:275
Advertised Duration:275 int./275 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.598 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.598 in.
Valve Lift with Factory Rocker Arm Ratio:0.598 int./0.598 exh.
Lobe Separation (degrees):111
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:Yes
Valve Springs Required:Yes
Camshaft Manufacturers Description:5.7-6.0L engines with Cathedral port cylinder heads, greatly improved power band over stock, computer tuning required, slight choppy idle, best for stock motors with bolt on parts and tight torque converter.
