1 - 7 of 7 Posts
2009silverato. Service airbag. Light on
Says drivers side delta belt tensioner has a loop
Tryed two front sensors
New module light still on
post the air bag code .
many have an electrical connection in the air bag circuitry.
Look for damaged wires, or connectors, going to the driver's seatbelt
LF seat belt pretension-er and the light is on then problem is more than likely a poor connection at the connector (if there was any kind of plastic clip or retainer on those connectors they must be in place and not broken in any way, also the wires going into the connector can't be stressed so get some dielectric lube and put on the terminals, look under the driver seat carefully for a wire rubbing the seat track.
Actually, when I said seat harness I guess I was thing about my old truck, the seat belt pre tensioner in your '09 will be inside the B pillar.
1 - 7 of 7 Posts
