1 - 13 of 13 Posts
Remove the connector from the clutch cycling switch on the accumulator(big metal can). Short the connector with a paper clip or whatever and then turn on the A/C. While you're doing that, check your freon charge. It should be around 30-50 PSI. If it's more than that, shut it off! That means you've got something blocking the line. If it's too low, add more freon, and see what happens. If it doesn't leak out, you're good.
Discussion Starter · #4 ·
So if the compressor turns on when I short the switch that means the switch is bad?
If it cools well with the pressure switch shorted, then yes, it's a bad switch. They have a schrader valve in the fitting so you can just screw it off and screw a new one right back on it. It try to do it with it running because the pressure is lower and you lose less freon if the valve happens to leak a little bit. By the way, it's called a "pressure cycling switch," so you ask for the correct part if you need one.
Good Luck and God Bless
Discussion Starter · #6 ·
Yippee, the compressor engaged when I shorted the switch with a paper clip. The air is not very cold though.
Do they still sell Freon for a 1992 at auto store to recharge the system?
Also where is the Schrader valve I’m unable to locate it? Thanks
Chances are the pressure switch is doing its job and the refrigerant charge is low. Dont run your A/C with the switch jumped out or you risk ruining the compressor.YThere should be a label near the emissions label telling what type and the amount of refrigerant you need. your auto parts store should have what you need to recharge your A/C. Good luck!
Also the schrader fitting is what the switch is threaded onto
Thanks for all the help. Unfortunately it says R 12 on the compressor so I guess I will have to convert it or can you still get it filled with R 12?
How would I pressure check the system before I try to refill it? I’d hate to spend the money to have it all leek out.
Discussion Starter · #10 ·
I found out someone has already switched it over to R134. I picked up a kit and went to add Freon and it seams to be holding pressure, still had to jump the switch to get the compressor to run and still no cold air once running.
Does this mean the compressor is bad?
If so how do you go about changing it? just diconnect everything, hook up a new one and refill?
More likely, you've got a block in the line. I would change the accumulator, front orifice tube, and rear expansion valve, and have everything flushed out, then refilled. I give good odds that the front orifice tube probably looks like a cat turd right now.
1 - 13 of 13 Posts
