1 - 7 of 7 Posts
I have read how to add a rearview mirror and display the ambient temperature in that mirror but do not know the difference between the LS and LT that keeps me from making modifications to the existing system to allow it to display the ambient temperature. Any help or does the display, computer, or whatever need to be changed?
I would recommend contacting your local dealership for more information. They are the best resource to let you know whether or not this is possible and what would be needed. Please feel free to keep me posted.
Tricia, GM Customer Service.
Thread moved to the Electrical forum for discussion.
Dont call your dealer....they wont tell you anything other than your truck didnt come with that feature and its not possible to make it work.
What you need to do is look at the support bars near your radiator to see if you have the sensors for the tempature....if you do then you could change the rear view mirror easily to one that diplays the temp.
If you dont have the sensor there are threads in this forum and on the web that tell you how to wire up the sensor and adding the aftermarket rear view mirror for temp display.
The dealerships are a good resource if your dealing with equipment that came on your truck...anything outside that they dont want the liability and wont mess with it.
For example, when I swapped out my stock gears I needed the Speedometer re calibrated...the dealer simply said they cant do that...they didnt have the means to do it??!!.
So what do they do when they add larger after market tires and wheels to the trucks on the lot? They have to let the computer know what size tires you have for proper speedo calibration!
Discussion Starter #5
I hate to say it but sstoner911 you are entirely correct. After taking the truck to the dealer, calling customer service and getting conflicting answers, I realized the dealership was correct in that they were not able to answer the question. I just feel this is an easy answer for the correct person but am disappointed that I can not buy the answer. I just don't understand why a 2010 $33000 truck did not have a compass and temp while a 2007 $15000 Pontiac did. It has to roll down an assembly line and different equipment installed for the LS and LT.
Just added one on my 99 C2500. I purchased the cable and sensor on EBAY, ran the cable and connected it to the black and green black wires comming from the mirror. I would advise checking a wiring diagram prior to adding this sensor as your wires colors may vary from mine. Locate the sensor in front of the radiator on the radiator support, you should be all set.
I hear ya... I wanted to add it to my truck but I found out that I didnt have the sensors for it and I quickly lost interest to other projects. My Sierra was 29,000 and I figured it was at least wired for it, however, I guess my trim level skips that part of the assembly line :)
1 - 7 of 7 Posts
