1 - 4 of 4 Posts
Had some recent A/C problems, blowing out hot air. Thought it was low on freon but could not locate the low pressure valve to add the freon. Anyone know where it's hiding?
Also found out that freon wasn't my problem though, had a belt to break, hopefully it didn't break because the compressor froze up
The charging valve is most likey on top of the compressor, it will be a snap on coupling not a screw on. hope you dont have compressor failure. You can bypass the low pressure switch, normally mounted on or near the receiver dryer to see if compressor if operating and to get a look at pressures. Add the recommeced amount of refrigerant typically a label on the dryer, or monitor the low pressue gauge and the temp coming out of the receiver drier to the comoprssor for a 8-12 degree superheat.
Hey Jeff, I don't know exactly where it is on yours, but it will be in the low pressure line. That's the large hose/line that runs from the compressor to the evaporator (from the compressor to the firewall).
Discussion Starter #4
Hey guys, thanks for the replies. We (myself and a friend that has the tools) did do a bypass and the compressor seemed to kick in, the belt was just mangled really bad and it gave me some fears. I was able to follow the low pressure line from the compress to the dryer and there were no valves anywhere. I'll have to take a closer look at the top of the compressor, it was difficult to get to as it's down at the front of the motor.
Thanks again.
Jeff
1 - 4 of 4 Posts
