RE: Ball joint replacement
Wow. I don't know if those are reasonable prices or not, I do my own. But the ball joints are fairly easy to replace if you're handy. Not to mention you'd see a huge price difference if you did it yourself.
Where did you get those price quotes?
Actually I see you have press fit lower ball joints, so depending on your capabilities it may be out of your scope of repair but the upper would still be pretty easy. Just to illustrate the highest price upper ball joint I'm seeing is about $42.99, and that's about a 30 - 45 min job depending on the mechanic. Lower would take a little longer. I can't say how long, since I've never done a press fit but I can't imagine it being more than an hour. So figure 4 hours total for all four ball joints, then factor in the alignment.
Sorry I can be of much more help there.
