went out to run some errands this evening, noticed it turned over slowly.
I figured it was the cold (high temp today was 12*),but every time I started it, it got slower,till it finally was dead. I got a jump, gauge showed 8 volts on the way home. had to drive home without lights.when I got home, I found a loose ground cable. was this loose ground cable the culprit?
