Best tire for me?
Best all around tires?
7539 Views 26 Replies 12 Participants Last post by  Steele-man
Hey everyone, I’m looking into buying a new set of tires for my truck. It’s an 06 Sierra 1500. (Z71, 4wheel, SLE model) Right now it’s stock height with turned keys in the front, but I’m going to put the 2.5” leveling kit from rough country (http://www.roughcountry.com/gm-leveling-lift-kit-283c.html) unless there’s a better one of course?
I should be able to run 285-295 tires with that kit, but I’m not sure what size exactly will fit/look good. I have 17x9 fuel “full blown” rims that have 265/70R17 tires on them. Any suggestions? I like a nice sized tire, but don’t want it to rub.
Lastly, I need a really good all around tire that actually looks good, I drive highway a lot, yet I still am in the mountains most weekends. I also need the tires to do well in snow, I’m up in Idaho often. I’ve had BigO Bigfoot A/T’s before and they were great, but not the best looking. The Bigfoot X/T’s seem good, any thoughts? I also am interested in the Nitto ridge grappler, how are they? The truck currently has Wild country radial xtx’s that the last owner had, their down on tread though so I can’t pass judgement. Thanks for the help!
Ps. Excuse the pictures, they’re from when I bought the truck a few months ago, I need to take some better pictures than I have right now of it.
21 - 27 of 27 Posts
Can you post some pictures? I think I want the leveling kit but I’d like to see it at stock height
Let me know if you want me to post a few more pictures/ what angle you want me to take them from. hope this helps. This is just what came on the truck. The cooper discoverer at3s are good tires by all means, but not what I would’ve picked. When I replace them I will be looking at either grabber x3s or nitto ridge grapplers.
Land vehicle Vehicle Car Automotive tire Tire
Land vehicle Tire Vehicle Car Alloy wheel
looks good, the AT3's are always one of the best rated tires too, i'm really considering going with the nitto terra grappler g2 or the cooper discover s/t maxx. I also think im going to go with 285/75/r17 because they are about an inch bigger than the 285/70's. Plus, im putting that leveling kit on, so a bit bigger will fit it better.
Nice truck BTW, it looks super good. do you not have much snow where you're at? I'm not sure how well those tires will do in snow.
In this thread it appears as though you are looking for a tire that will do it all. Highway, mountains, snow and ice. Highway noise is a factor as well so I assume you spend a lot of your time on the highway.
I occasionally have had to drive through some terrible conditions but in thinking about it, that would only have make up a very small percentage of the time I drove. For that reason I'll drive on an all season tires and take my chances in bad weather. If it's bad I'll drive very carefully. If it's real bad just keep of the road because you'll probably get stuck unless you are driving a snowplow.
I can relate to your mountain weekends. I spent most of my weekends at the lake before retiring. I commuted back and forth in all sorts of conditions every weekend mainly because it was more important to be out here than it was important to worry about the drive.
Now I live out at the lake. My main worry is what happens if I have to get out in a hurry. Fortunately they keep the roads clear out here. I'm on a school bus road. We get the snowplows first.
In the ten years or so that I've lived out here I don't think I have been snowbound for more than ten hours. Nothing I would ever own would have got me out in those ten hours so what's the sense of thinking about a tire that might get me halfway out.
If you spend a lot of time driving in bad conditions then you should be looking for that sort of tire. Keep in mind that tires made for bad conditions aren't so good in good condition and visa versa. As the saying goes "If you try to please everyone you end up pleasing no one."
The safest but most expensive option is to have two sets of tires. Summer and winter. The initial cost is prohibitive but in the long run your tires will last a lot longer.
There is one option worth considering. Chains, or one of the new high tech versions of them. They may be a nuisance to get on and off but how often would you need them?
Thanks. I’m in SW OH - we get some snow but nothing major really. These tires do fine in the snow for the most part but I have only driven on snow with it in 4HI...thats probably part of the reason. Plus the tires only have between 40-50% tread left so they spin a little sometimes. I am also considering the RC leveling kit for mine before I get new tires so I can go a little bit bigger. Still not sure which tires I want though...I love the Grabber x3 but they are loud and a bit much for my uses but we’ll see. I’d love to see some pictures of your truck once your finished with the level and the new tires. It’s gonna look awesome.
I’ll post it when I’m done, it’ll be a couple month probobly, I need to save a little bit and convince my wife lol
On this same topic, the rough country leveling kit comes with N3 shocks, I found a lot about the 2.2’s on here and it sounds like bilsteins are better, but what about the newer 3.0’s???
Also, I don’t do a ton of towing, but we’re looking into buying a camper in a year or so and towing it a lot. Should I just add a leaf while I’m already doing the lift kit? Or, is doing airbags better long term?
If anyone has done a lot of suspension stiff, let me know.
I would re-evaluate what you want if this is the route you want to take. Skip the kit you linked to in the first post and just get the one that just has keys and shock mounts, if your shocks are still good that saves you money there, if not oh well. Instead of putting taller blocks in back just do the aal, that’s gonna raise the rear too, dont wanna do both or the front will be nose diving.
Update: Ended up going with 285/70/r17 like everyone else, but I went with Hurcules Terra tracks, so far they’re awesome on every condition I’ve faced! Going to add some bilstien shocks (need new ones anyway) for just a hair better level and more highly, but I love how it looked!
21 - 27 of 27 Posts
