Hello to all.. I've got a problem with the blend door hanging on the air diverter valve. The rod that controls the blend door, travels to the air diverter valve ,and is held in place by a plastic clip. The puzzling thing of it is that the air diverter will rotate freely to one side of the plenum to the other, and the air pressure from the fan pushes the diverter in front of the blend door to obstruct the blend doors travel. I've called the dealer to ask if they see in their parts book of anything that limits the air diverter's travel and they say no, that the air diverter is adjusted on top of the plenum with the rod that connects to the plastic clip. But if the diverter is not snug on the rod that the blend door operates then it can't be adjusted. If anyone has any insight to this I would be very grateful.
1989 Chevy Suburban
5.7 L
700R4
Thanks Again
Swoop
1989 Chevy Suburban
5.7 L
700R4
Thanks Again
Swoop
