I don't think all marine engines are reverse rotation, because I swear I've seen engines listed in all 4 configurations : car/normal rotation, car/reverse rotation, marine/regular, marine/reverse. One thing you may want to consider is that marine engines are designed to be cooled by the water the boat is sitting in. I think the water pump is different because of this, but a car water pump should be cheap and have the same mounting bosses as a marine pump. You would also have to source a complete accessory drive for it, and the marine engine may not have the mounting bosses drilled and tapped.
That all said, a marine engine would be a nearly unstoppable force in a car. Marine engines are designed to run fast, with a huge load, for long periods of time. Sounds like a winning combination in my book. Marine engines also cost a lot more, if I remember correctly. Research it some, and I'm sure you'll find all the info you need.
