1 - 2 of 2 Posts
[h=2][/h]
Ok so when i hit the brakes and the head lights are off my brake lights work perfect but when i turn my light on and hit my brakes there are no brake lights and instead both of my running lights and blinkers light up what could be my problem and how to fix it and tips will help and is this common or not on a 96 z71​
Sounds like you have a bad ground to the tail lamps. Check under the rear of the box. There should be a ring connector bolted to the frame. Make sure the surface is clean and shiny, that there is a star washer present, and the bolt is good and snug. Also make sure the ground wire itself is not broken or damaged.
Good Luck and God Bless
1 - 2 of 2 Posts
