1 - 3 of 3 Posts
[h=2][/h]
Ok so when i hit the brakes and the head lights are off my brake lights work perfect but when i turn my light on and hit my brakes there are no brake lights and instead both of my running lights and blinkers light up what could be my problem and how to fix it and tips will help and is this common or not on a 96 z71​
Check the grounds out under the rear of the pickup box. You have "floating" ground. It's finding ground through the lighting circuit. Probably a rusted ground bolt, or a broken ground wire.
Good Luck and God Bless.
1 - 3 of 3 Posts
