I bought this van with a blown engine. After doing some research I found it was cheaper for me to buy all new parts rather than have my old parts machined! So I bought a summit bare block .030 over and already modified for the stroker, I went with Scat and got their 9000 series rotating assy w/forged pistons and floating pins. The heads were the same scenario, To have them machined was an arm and a leg so I found that Patriot Performance had a pair of aluminum heads (vortec design still) that were modified with larger valves and already had screw in rocker studs and valve springs able to handle up to a .550 lift. Part #2169 from summit. went with a comp cams roller cam for truck use and new roller lifters and roller rockers. It should run good when it is all together. Headers were the toughest thing to find!! No one makes them for this van (long tube ones that is) But I found That Doug Thorley makes a pair that are for a bus that are based off of the express chassis. So now That everything is moving in the right direction I would like to find info on how to convert it to AWD!! not finding much on line!! Anyone thought to do this before and have a source for parts or part numbers that can help do it? Thanks Chuck
PS I just found this forum and already love the topics being posted!!
arty:
