1 - 2 of 2 Posts
Engine is located near Ironia, NJ. Due to other life priorities, I am abandoning my project and selling my built 4.3 liter Chevy/GMC engine. I have my old 1986 S10 which this was supposed to go into, but adding a kid and moving to where I have no place to work means this engine has got to go. I've been fooling myself that I will get to this project for way too long.
Comp Cams Magnum Hydraulic Roller Cam and Roller kit - CL09-412-8
Melling High pressure oil pump M-55A
Low Friction coated aluminum pistons
Comp Cam bee hive springs and valve retainers
Chevy Performance Parts bolt kit used for heads, etc.
Heads and all other works by P&W Automotive Machining out of Whippany, NJ
Boiled, line bored, bored .030 over, balanced, new freeze plugs, double roller timing chain, etc., etc.
Engine Stand will be included with sale.
Asking $2000 or best offer. As you can see from the receipt, I have $2400 into this motor before all of the accessory and other brackets were installed. The plan was to replace the old alternator, rollers, and pulleys from the original truck. I can also just remove the accessory brackets all together. Your call.
1 - 2 of 2 Posts
