1 - 20 of 33 Posts
What is the Difference in the 3/4 ton and the ton I have the bigger trans and a 14 bolt rear end . However just was wanting to know why I have been told can't pull over 10.000 lbs looking to buy a Fifth wheel . It reads in door panel 8600lbs The rear on this truck has heavy duty springs and takes a lot to make her squat down . What is your thoughts ? I'm new to site so please help !!
Thank You
1999 Silverado 5.7 vortex 4x4 3/4 ton long bed Reg Cab
Maybe (for that year) it was duals on the rear that turned the 2500 into a 3500, rear end gear ratio is also a towing factor.
Remember, there is also a HD version of the 2500 which is rated higher; and, the addition of 4x4 lowers the towing capacity.
EDIT: as I think about it, the HD (heavy duty) may not have been available in 1999.
Penny sorry I started this and fell asleep, I am looking into this I did find the Hd version was a heavy build and could tow upwards of 18,000 but haven't yet found the c/k 2500 Silverado most likely because of the overlapping series, but I am still looking. I know for a fact you can tow what you need to, with a gooseneck installed. May need air assist in the back, but then should be good.
The Chevrolet Silverado and its mechanically identical cousin, the GMC Sierra is a series of full-size and heavy-duty pickup trucksmanufactured by General Motors and introduced in 1998 as the successor to the long-running Chevrolet C/K line. The Silverado name was taken from a trim level previously used on its predecessor, the Chevrolet C/K pickup trucks and Suburbans from 1975 through 1999. General Motors continues to offer a GMC-badged variant of the Chevrolet full-size pickup under the GMC Sierra name, first used in 1988 for its variant of the GMT400platform trucks
  • Like
Reactions: Penny
Thank You
I think mine has 7 possibly 8 leafs in the rear and have never made it squat in the back
  • Like
Reactions: Penny
Here is the simple brake down, a half ton pick up means that it is rated to haul 1000 pounds in the bed of the truck, 3/4 ton 1500 pounds in the bed, and 1 ton 2000 pounds in the bed. All the manufactures like to confuse you and call the 1/2 ton a 1500, and a 3/4 ton a 2500, and a 1 ton a 3500, but these numbers are only a name sake.
Agreed Kenny , but it is the towing weight in question not hauling addressed separately. Look it up just bring up the spec sheet. I am just having a tough time matching her particular truck to spec. 1st year of second gen but yet overlapping models in production. I for one will be very interested in the 4l80e that she has and it's presentation to the engine.
  • Like
Reactions: Penny
Discussion Starter · #7 · (Edited)
A friend looked at the Drums and they are huge .
Hey thanks to you all the info your giving is better then I have received to date thanks a million . I failed to say it has the cooler as well on trans I will soon own this truck a year im 2nd owner only has 174.000 so not really sure of what I , can do .BTW the manual has c/k 2500 on it . All info is Appreciated . If you have more great . I will soon have my hitch installed !:)
Not sure what ya mean on air assist ?
Penny , this is what I have been able to come up with at this time.
This is for the 96 version K2500 Hd It has the 13" rear drums and you are correct they are big, and the 5.7 350 Mtr mated to a 4l80e and 3.73 axels. 10,000# with weight distributing hitch.
Technical Specifications
Technical Data
Body Style:
HD Reg Cab 8' Fleetside
Drivetrain:
4-Wheel Drive
Passenger Capacity:
3
Engine Type:
HD Gas V8
Displacement:
5.7L/350
Fuel System:
SFI
SAE Net Horsepower @ RPM:
255 @ 4600
SAE Net Torque @ RPM:
330 @ 2800
Trans Description Cont.:
HD Manual w/OD,
Front Tire Size:
LT245/75R16E
Rear Tire Size:
LT245/75R16E
Spare Tire Size:
LT245/75R16E
Front Wheel Size (in):
16 x 6.5
Rear Wheel Size (in):
16 x 6.5
Front Wheel Material:
Steel
Rear Wheel Material:
Steel
Brake ABS System:
Four Wheel
Disc - Front (Yes or ):
Yes
Fuel Tank Capacity, Approx (gal):
34
Wheelbase (in):
131.5
Advanced Technical Data
Body Code:
E63
Gross Axle Wt Rating - Front (lbs):
4250
Gross Axle Wt Rating - Rear (lbs):
6000
Curb Weight - Front (lbs):
2735
Curb Weight - Rear (lbs):
1905
Gross Vehicle Weight Rating Cap (lbs):
8600
Gross Combined Wt Rating (lbs):
12,000
Dead Weight Hitch - Max Trailer Wt. (lbs):
4000
Dead Weight Hitch - Max Tongue Wt. (lbs):
400
Wt Distributing Hitch - Max Trailer Wt. (lbs):
10,000
Wt Distributing Hitch - Max Tongue Wt. (lbs):
1000
Engine Order Code:
L31
Trans Order Code:
MW3
Trans Type:
5
Trans Description Cont. Again:
Deep Low
First Gear Ratio :)1):
5.61
Second Gear Ratio :)1):
3.04
Third Gear Ratio :)1):
1.67
Fourth Gear Ratio :)1):
1.00
Fifth Gear Ratio :)1):
0.75
Reverse Ratio :)1):
5.61
Clutch Size (in):
12
Trans Power Take Off:
SAE 6-Bolt
Trans PTO Access:
RH
Transfer Case Model:
New Process 241
Transfer Case Gear Ratio :)1), High:
1.00
Transfer Case Gear Ratio :)1), Low:
2.72
Cold Cranking Amps @ 0° F (Primary):
600
Cold Cranking Amps @ 0° F (2nd):
600
Maximum Alternator Capacity (amps):
100
Maximum Alternator Watts:
1200
Total Cooling System Capacity (qts):
17.1
Engine Oil Cooler:
Yes
Frame Type:
Ladder
Suspension Type - Front:
Indep Torsion Bar
Suspension Type - Rear:
2-Stage Multi-Leaf
Spring Capacity - Front (lbs):
4250
Spring Capacity - Rear (lbs):
6084
Axle Type - Front:
Independent GM
Axle Type - Rear:
Semi-Floating
Axle Capacity - Front (lbs):
4250
Axle Capacity - Rear (lbs):
6000
Axle Ratio :)1) - Front:
3.73
Axle Ratio :)1) - Rear:
3.73
Shock Absorber Diameter - Front (mm):
35
Shock Absorber Diameter - Rear (mm):
35
Stabilizer Bar Diameter - Front (in):
1.18
Front Tire Order Code:
XHH
Rear Tire Order Code:
YHH
Spare Tire Order Code:
ZHH
Front Tire Capacity (lbs):
2205
Rear Tire Capacity (lbs):
3042
Spare Tire Capacity (lbs):
3042
Revolutions/Mile @ 45 mph - Front:
678
Revolutions/Mile @ 45 mph - Rear:
678
Revolutions/Mile @ 45 mph - Spare:
678
Spare Wheel Size (in):
16 x 6.5
Spare Wheel Material:
Steel
Steering Type:
Power
Steering Ratio :)1), On Center:
16.4
Steering Ratio :)1), At Lock:
16.3
Turning Diameter - Curb to Curb (ft):
44.7
Turning Diameter - Wall to Wall (ft):
48.6
Brake Type:
Power
Front Brake Rotor Diam x Thickness (in):
12.50 x 1.26
Drum - Rear (Yes or ):
Yes
Rear Drum Diam x Width (in):
13.0 x 2.5
Fuel Tank Location:
Inboard LH Frame
Front Head Room (in):
39.9
Front Leg Room (in):
41.7
Front Shoulder Room (in):
65.4
Front Hip Room (in):
60.0
Length, Overall w/o rear bumper (in):
213.4
Width, Max w/o mirrors (in):
76.8
Height, Overall (in):
75.8
Overhang, Front (in):
35.4
Overhang, Rear w/o bumper (in):
52.2
Front Bumper to Back of Cab (in):
111.0
Cab to Axle (in):
55.9
Ground to Top of Load Floor (in):
33.4
Frame Width, Rear (in):
36.7
Ground Clearance, Front (in):
7.8
Ground Clearance, Rear (in):
8.1
Cargo Box Length @ Floor (in):
97.6
Cargo Box Width @ Top, Rear (in):
61.9
Cargo Box Width @ Floor (in):
64.4
Cargo Box Width @ Wheelhousings (in):
49.1
Cargo Box (Area) Height (in):
19.2
Tailgate Width (in):
62.0
Cargo Volume (ft³):
69.1
  • Like
Reactions: Penny
Discussion Starter · #13 ·
Technical Data
Body Style:
Drivetrain:
4-Wheel Drive
Passenger Capacity:
3
Engine Type:
HD Gas V8
Displacement:
5.7L/350
Fuel System:
SFI
255 @ 4600
330 @ 2800
HD Manual w/OD,
Front Tire Size:
LT245/75R16E
Rear Tire Size:
LT245/75R16E
Spare Tire Size:
LT245/75R16E
16 x 6.5
16 x 6.5
Steel
Steel
Brake ABS System:
Four Wheel
Yes
34
Wheelbase (in):
131.5
Body Code:
E63
4250
6000
2735
1905
8600
12,000
4000
400
10,000
1000
Engine Order Code:
L31
Trans Order Code:
MW3
Trans Type:
5
Deep Low
5.61
3.04
1.67
1.00
0.75
Reverse Ratio :)1):
5.61
Clutch Size (in):
12
SAE 6-Bolt
Trans PTO Access:
RH
New Process 241
1.00
2.72
600
600
100
1200
17.1
Engine Oil Cooler:
Yes
Frame Type:
Ladder
Indep Torsion Bar
2-Stage Multi-Leaf
4250
6084
Axle Type - Front:
Independent GM
Axle Type - Rear:
Semi-Floating
4250
6000
3.73
3.73
35
35
1.18
XHH
YHH
ZHH
2205
3042
3042
678
678
678
16 x 6.5
Steel
Steering Type:
Power
16.4
16.3
44.7
48.6
Brake Type:
Power
12.50 x 1.26
Yes
13.0 x 2.5
Fuel Tank Location:
Inboard LH Frame
39.9
41.7
65.4
60.0
213.4
76.8
75.8
35.4
52.2
111.0
Cab to Axle (in):
55.9
33.4
36.7
7.8
8.1
97.6
61.9
64.4
49.1
19.2
62.0
Cargo Volume (ft³):
69.1
Thank You Chester great info !!
Have no idea where all those smiles came from
Thank You
by the way, that is a nice looking truck.
So being on the farm, have never been concerned with tow limits, only (hell Chet, I think that's to much!) 10,000 a problem, or no? <Wisconsin coming out in me.
Thanks Kenny, overlapping models in 99 kinda tough, do you know what years the tranny's match as far as bell housing connections are concerned? For the 400 series?
Kenny, Ok, I have been told that the 96 was a strange duck! And could not use the previous year's trannies, if so what would the difference be? I guess I am wrong with your post, but would like to know where the difference could possibly be?
Thanks Kenny I do appreciate it, and I hate giving bad info out.
That's why I hesitate to answer at times. I know hard to be leave that part :)
1 - 20 of 33 Posts
