1 - 4 of 4 Posts
Hey guys I have a 1993 GMC ck3500 4x4 dually and I have a weird question that I need answered. I have heard of it before but haven't seen it done so I am wondering if it possible, but first off ill start off with my reason for asking. I plow with it in the winter and I do work it fairly hard and the blade I am pushing is a beast it is a 9ft western straight blade and it is about 2'1/2 - 2'3/4 ft tall so it is a bit of a beast it weighs probably around 900 pounds. And being IFS in the front it is torsion bar and it is pretty weak it sags quit a bit with the blade when I lift it. And I don't really have the time to take it off the road and put in new torsion bars etc, so I am wondering is it possible to some how weld pockets to the A-arms and to the frame and add coils as helpers?? Have any of you ever heard of this being done??
Thanks for any help guys.
Super Moderator
Not sure if yours is the same as my 96 1500 with torsion springs.
On mine at the rear of the spring there is a ride height adjustment screw where the spring goes into the cross member by the trans. You could just crank it up a bit to help with the sag.
I would think it would take a LOT longer to fabricate and weld in spring pockets than to replace the torsion springs.
Discussion Starter #3
@Flyinfool Yes mine do have adjusters but they are seized tight I tried loobing them everyday for about 2 weeks and they still wont turn. And I was thinking if the coils could be done then if I get a day here and there I can weld a pocket here and there and slowly work at it since it doesn't need them to drive unlike the torsion bars.
If they are seized and you absolutely cannot get them loose [try the big red wrench], try finding air shocks for the front or cellular bump stops that are extended. Seriously though, an oxy torch on the bolt NOT the key should solve your problem.
1 - 4 of 4 Posts
