I'm running a 355 small block in my 94 z71 and I'm thinking about putting a 4 barrel carb on it doing away with the TBI. My ? is can I get by with a fuel reg. or do I need to drop the tank and put in a new pick up and a pump on the block to make it run right with the carb.
You can get an adjustable FPR and it will work just fine.
Discussion Starter #3
cool thanks. i got to get more ponys out of this motor some how i've got headers and MSD ing. and it acts like it is straving for fuel on the top end i've got tons of low end but its weak on the top
that sounds more like a weak pump or crummy distibutor problems. Since the TBI will support a 355.. but trying to carb might help if you dont want the EFI.
Discussion Starter #5
new pump but i might look at my distibutor i have a msd set i was gonna put in when i changed the intake i might chang it frist and see what happens
