Ok iam hoping someone can help me out with this i have a 2010 silverado and iam adding the ccfl led halo projector headlights and when it comes to the wiring part im completley useless bare with me. everything is fine with install untill hooking up the led and halos on the back of headlight i have the main male connector and then i have loose wires a set of red and black for the halos and a set of purple and black for led i would assume purple is positive and black still negative my question is to both positives get wired together and same for negative?? and if so where do i splice the wires into my system after for best look??? any help asap would be great as i want to install tonight thank you!!
