1 - 8 of 8 Posts
My 05 Silverado check enging light went out when I replaced the gas cap. It came back on after 2 tanks of gas and won't go out now. Advance Auto Parts read the code and it still is still saying it is a bad gas cap. They replaced the new cap but the light is still on. What else could it be? I don't know exactly what the code read but they said something about a bad solenoid which they said meant gas cap.
It is picking up a slight EVAP system leak that normally is repaired by tightening or replacing the gas cap, but if it has come back, you may have a leak in one of the vent hoses between the gas tank and the engine.
Sounds like the EVAP solenoid has either gone bad or become disconnected and is causing a vacuum leak. There may be an emission diagram under the hood showing it's location.
Discussion Starter · #6 ·
I found the evap soloniod release valve on the top of the engine. I unscrewed it and found a valve like you would find on a tire. Should I push it to see if that helps clear the problem? Would it cause damage or problems if I did?
I have had this happen several times- each time because the wife put gas in and did not have the gas cap tight enough- i.e. there was not back pressure in the gas tank. Each time, I tightened it down, and sure enough the light went out after 3-4 starts.
I also remember this happening repeated each time she filled up at one particular gas station.... Since this is an emmissions issue, I wonder if bad gas could cause this to happen ?
1 - 8 of 8 Posts
