Chevy Avalanche serpentine belt replacement
13044 Views 1 Reply 1 Participant Last post by  ChevyFan
Replacing the serpentine belt on your Avalanche is similar to any GM truck these days.
Look for the grey idler pulley, hook in a 5/8 socket on a 1/2 drive breaker bar and pull. Make sure you have a good connection.
The whole process takes about 5 minutes, you should have a diagram on your fan shroud to show how the belt gets routed if you forget.
Chevy parts www.gmpartsclub.com You can find the serpentine belt here for all chevy trucks.
1 - 2 of 2 Posts
Two belts in the Avalanche
Most Avalanches have A/C anymore, the AC is driven off a 2nd belt for any Avalanches (2002-2005 at least). It's behind the big serpentine and has it's own idler adjuster.
1 - 2 of 2 Posts
