Update. I have not posted much. Bought my truck 7 months ago. 91 Topkick 7000 16 ft dump wood bed.366 tbi, 5 speed single axle. The truck had been sitting for 15 years. bed floor rotten (gone) side good. no tailgate. Had the split rings on it with 9.00x 20 tires. The first plan was to go with 10 hole unimounts. Found out would be too expensive. So fount some newer Daytons and 11 r 22.5 tire ( not great). Drained old gas put fresh in. Fired right up. Would not come off idle, found the butterflies stuck. The original plan was to get it driveable and drive it home (120 miles). The last trip up was to do tires and replace rubber brake lines and the steel line that blew out (exterior rust) Got 8 ft of steel line down the frame replaced and 3 rubber lines on rear replaced. Still no decent brakes. Did not tackle the front because of fitting strippping. Plus I think front calipers are frozen or locking up, possible bad master cylinder.
The wife and I talked about it and decided to check on getting it brought home. Find a guy that would do it for 650. So we had it brought home. Get it ready to tow was a bunch of stuff in bed, we had not been able to get the bed to dump. Took the dust cover off the pump control and disconnected the cable dump works cable frozen.
Off idle can here a slight miss
Need to order a shop manual for it.
I do have one question. How do you adjust the power steering belt? I have loosened everything except the bolts in the pump itself.
Also does any have a top for the battery box?
