Well, I'm new here. Bought a 97 Tahoe LT 4 door 4x4 back in November 17. I bought it knowing it had a bad spider injection assembly and cracked intake manifold. I could smell no gas in the oil and it had good compression on all cylinders. I first replace the intake manifold and bought a used injection assembly. Installed the used unit and had a problem with it hydrolocking. Found #5 and #7 cylinders full of fuel both times it happened and figured I would swap them with the #5 and #7 injectors from my old assembly. Put it all back together to have it hydrolock again. Found the used assembly I had bough had a crack in the meter body that could only be detected because I pulled the intake manifold and pressurized the system to see what was happening. At that point I broke down and spent the money on the updated injectors. Got them new for $189.00 on amazon. After installing the new assembly, it started and ran great, the steering and handling was then an issue. So I replace the worn out front suspension and steering systems, including the gear box. So, was feeling pretty good with it. Then the starter went out. Installed a new starter. Now I'm having a grounding issue. Needless to say, I've spent a lot of time on this vehicle and used to own a 96 Tahoe, which I loved. I've noticed that this particular Tahoe seems to have had someone trying to customize it themselves without the proper knowledge and without taking the time to do the proper research to do it correctly or just didn't really care to do it right (wiring spliced, bolts missing in spots, radio incorrectly spliced in, door panels on back doors put back on with sheet metal screws instead of the $5/50 clips, etc.). I will eventually get the kinks worked out but I'm wishing I would have gotten it for less than the $900 I paid for it. Lol. Wish me luck on restoring this one to its former glory.
